When i try to create form number 2 i get this error:
Violation of PRIMARY KEY constraint 'PK_UFForms'. Cannot insert duplicate key in object 'dbo.UFForms'. The duplicate key value is (6f2903fc-e27a-4d68-88d7-8d948746a6fe).
Here is the content from the database:
The id is the same, but i think i choould just create a new one on the next row.
Either install diretcly from the umbraco repository, or install the Contour 3.0.6.zip (newer versions won't work) as a local package under developer / packages in the umbraco backoffice
So i can not install 3.0.7 on the Umbraco version 4.11.4 - and for the moment i do not want to upgrade to Umbraco version 6.0
You could update the form templates (found in \Umbraco\plugins\umbracoContour\templates ) and update the id from what it is (all the way at the bottom) to all zeros
Violation of PRIMARY KEY - Contour
Contour version 3.0.6
I m only allowed to create 1 form.
Any suggestions?
Best regards René
HI again
I have looked at this a little futher.
It is only if i choose the template "Contact", if i choose "none" it works.
Comment author was deleted
Yeah it's a bug in 3.0.6 that got fixed in 3.0.7 http://nightly.umbraco.org/Umbraco%20Contour/3.0.7/changes.txt
But at the http://our.umbraco.org/projects/umbraco-pro/contour it says
To install on Umbraco 4.X
Kindly René
Hi Tim
Just vant to be sure of what you mean...
Is it this you mean, that every ID i set to 00000000-0000-0000-0000-000000000000 AFTER i Update vith the versions from Contour 3.0.7
Just the one at the bottom so before the </form> tag the rest doesn't matter
