I created a from and exported it. If I try to create a new form by importing this form or by using it as a template I get the following error :
Already found the problem. Changed the ID of the form to another guid in the ucf file and it works now.
Comment author was deleted
Yeah bug in 3.0.6 but fixed in 3.0.7
Import / template problem
Violation of PRIMARY KEY constraint 'PK_UFForms'. Cannot insert duplicate key in object 'dbo.UFForms'.
The statement has been terminated.
