I am pretty new into umbraco and in the learning phase of Umbraco, presently trying to integrate umbraco with a cms website.
I came to know about the contour feature from the umbraco videos. downloaded the package and its showing :- Umbraco Contour is running in trial mode - data from fields in submitted forms will not be saved. Order the full version today!
Before i get the license, can anyone tell me what are the extra features/functionality i am going to get after buying the contour lisence ?.
All features and functionality is availabl ein trail, it's just that in trail it doesn't save your value but a placeholder instead "contour is running in trail mode"
It doesn't save Value? can you please explain that . I added a contact form .And it worked fine.No such notification like"contour is running in trail mode" is being shown in the front end. it only shows in the admin panel. Since i am working in local debug mode, just trying to confirm that is will also work in the live server..
Difference between Contour trial and full version.
Comment author was deleted
Hey Tim thanks for your reply.
Yeah when running localy you don't have that limitation :)
Once you deploy this to the live server you'll get the trial mode
