Save as file - xslt transformed - string-length problem
Hi forum
I'm trying to save form entries in a file using som xslt transformation. I'm pretty new to this so please bear with me if this is a totally noob question.
I'm trying to count the string length of the value field but I must be doing something wrong. This is my xslt-file so far - which isn't working:
it works as expected, but I can't figure out how to reference the value of the value tag. I think I may have to assign the value to a variable and use that, but I don't know how to do this.
Can anyone please help me?
Best regards, Michael
Additional question: The default "Save as file"-workflow has an option to name file extension. I put "txt" in this field but it still saves the file as .xml. Can we do anything about this?
Hi forum
<?xml version="1.0" encoding="utf-8"?> <xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxsl="urn:schemas-microsoft-com:xslt" xmlns:user="urn:my-scripts" xmlns:umbraco.library="urn:umbraco.library" version="1.0" exclude-result-prefixes="xsl msxsl user umbraco.library"> <xsl:output method="text" media-type="text/plain" indent="no" encoding="utf-8"/> <xsl:param name="records"/> <xsl:template match="/"> <xsl:for-each select="$records//fields/child::*"> <xsl:sort select="@pageindex" order="ascending"/> <xsl:sort select="@fieldsetindex" order="ascending"/> <xsl:sort select="@sortorder" order="ascending"/> <xsl:choose> <xsl:when test="@fieldsetindex = 0"> <xsl:if test="@sortorder = 0">10</xsl:if> <xsl:value-of select=".//value"/> </xsl:when> <xsl:otherwise> <xsl:if test="@sortorder = 0"><xsl:text> </xsl:text>20</xsl:if> <xsl:value-of select=".//value"/> <xsl:if test="string-length(.//value) < 30"> <xsl:text> - </xsl:text> </xsl:if> </xsl:otherwise> </xsl:choose> </xsl:for-each> <xsl:text> </xsl:text> </xsl:template> </xsl:stylesheet>If I put some constant string in string-length like this
<xsl:if test="string-length('some string') < 30">it works as expected, but I can't figure out how to reference the value of the value tag. I think I may have to assign the value to a variable and use that, but I don't know how to do this.
Best regards,
Michael
Comment author was deleted
Hi Michael
And does the <xsl:value-ofselect=".//value"/> tag output anything?
Maybe you'll need to cast to string first
For the save as file workflow I've added the issue to our tracker and a fix should be part of the next maintenance release
http://issues.umbraco.org/issue/CON-269
Hi Tim
Thanks, that did the trick! Great!
I'll keep an eye out for the next release for the fix regarding the issue with file extensions.
Michael
