Have a view template for each field, but these no longer work, one renders nothing, the other fails with this exception.
Message=No node exists with id '1410' Source=cms StackTrace: at umbraco.cms.businesslogic.CMSNode.setupNode() at umbraco.cms.businesslogic.member.Member.setupNode() at Umbraco.Forms.Data.StringHelper.(String , Object ) at Umbraco.Forms.Data.StringHelper.ParsePlaceHolders(HttpContext Context, Record record, String value) at Umbraco.Forms.Mvc.Models.FormViewModel.FetchRecordValues(Field field, Record record) in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.Mvc\Models\FormViewModel.cs:line 185 at Umbraco.Forms.Mvc.Models.FormViewModel.Build() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.Mvc\Models\FormViewModel.cs:line 115 at Umbraco.Forms.Mvc.Controllers.FormRenderController.ContourForm() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.Mvc\Controllers\FormRenderController.cs:line 54 at lambda_method(Closure , ControllerBase , Object[] ) at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters) at System.Web.Mvc.ControllerActionInvoker.<>c__DisplayClass15.<InvokeActionMethodWithFilters>b__12() at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation) InnerException:
I 'm after an example of a multicontrol field using a view template with the processing within the fieldtype dll
It does :) those support both webforms and mvc, for mvc you'll need a view and possible a custom ProcessValue method (take a look at the upload control)
finally had another look at this. Yes I now see that all pre-processing needs to be initiated from within the view (makes sense of course but a bit of a rewrite in my case).
further to the actual error reported above, its actually related to the default values my custom fields use;
Contour 3 multi control field in MVC
Running 4.11.4 with Contour 3.0.6
default rendering is MVC
have removed ContourFormBuilderHttpModule from web.config
have Contour 1x versions of custom fields - which work fine with webform templates (even with default render as MVC)
these custom fields render multiple controls, in debug the Editor method doesnt get called when used in MVC template;
or
how to get a 1x fieldtype to work in MVC
W
Comment author was deleted
Yes the Editor property isn't used for the mvc part since it returns a webcontrol...
To see how to update for mvc support take a look at the default providers sourcecode: http://our.umbraco.org/FileDownload?id=5060
Ok, thought that would have been the case.
The source code mentioned does not support MVC, all the fieldTypes in the source still only have the Editor property and return a webcontrol....
Is there an updated version for MVC ?
I expanded the intital concept of default value parameters http://our.umbraco.org/forum/umbraco-pro/contour/15471-Default-values-parameters-from-session with a curly backet syntax.
e,g {member.Name} and {member.email} which uses the current membership provider
The use of '{}' around a default value on any contour fieldtype seems to be the cause - for me anyway..........
