Custom razor markup, different guid on each environment
hi, i have this kind of problem i have 3 enviorments: dev,stage, prod.
i have a contour form with a custom razor markup that exist in a folder in my dev area, the name of the folder is the guid of the form. when i import the form i have a diffrent guid for the form so i need to maintain 2 copies of the custom markup, and if i create it in the prod enviorment i will need to maintain 3 copies of the form.
is there any solution to this kind of problem?
Comment author was deleted
Good point, added to the issue tracker and I'll see what we can do about this
