  • Eran Meir 401 posts 543 karma points
    Feb 23, 2013 @ 13:01
    Eran Meir
    Custom razor markup, different guid on each environment
    hi, i have this kind of problem
    i have 3 enviorments: dev,stage, prod.
    i have a contour form with a custom razor markup that exist in a folder in my dev area, the name of the folder is the guid of the form.
    when i import the form i have a diffrent guid for the form so i need to maintain 2 copies of the custom markup, and if i create it in the prod enviorment i will need to maintain 3 copies of the form.
    is there any solution to this kind of problem?
  • Comment author was deleted
    Feb 25, 2013 @ 09:47
    Good point, added to the issue tracker and I'll see what we can do about this
