  • Phil Dye 149 posts 325 karma points
    Feb 26, 2013 @ 16:57
    Phil Dye
    Licensing for multi-site instances
    We have a client about to launch a multi-site setup in Umbraco (with 4 similar sites in one instance, each on separate domains) - what Contour license is needed for this; one primary with three add-on domains, or 4 primary licenses (and if so, how is the license key file for that handled, in one bin folder)?
    Phil
  • Comment author was deleted
    Feb 26, 2013 @ 17:20
    1 primary with 3 add-on domains should do it :)
    Feb 26, 2013 @ 17:22
    Phil Dye
    Thanks Tim, order coming your way shortly...
