  • Anton Oosthuizen 206 posts 486 karma points
    Feb 27, 2013 @ 05:55
    Anton Oosthuizen
    Contour Index was outside the bounds of the array.
    Hi im using umbraco 6 with contour 3 and I am getting an Index out of range error. An cant access the website at all.
    Stack trace
    [IndexOutOfRangeException: Index was outside the bounds of the array.]
       Umbraco.Forms.CodeFirst.FormManager.<SynchronizeForm>b__22(String x) in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\FormBuilder\FormManager.cs:389
       System.Linq.Enumerable.ToDictionary(IEnumerable`1 source, Func`2 keySelector, Func`2 elementSelector, IEqualityComparer`1 comparer) +250
       System.Linq.Enumerable.ToDictionary(IEnumerable`1 source, Func`2 keySelector, Func`2 elementSelector) +90
       Umbraco.Forms.CodeFirst.FormManager.SynchronizeForm(Type typeForm) in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\FormBuilder\FormManager.cs:389
       Umbraco.Forms.CodeFirst.FormManager.SynchronizeForms() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\FormBuilder\FormManager.cs:201
       Umbraco.Forms.CodeFirst.FormManager.Synchronize() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\FormBuilder\FormManager.cs:24
       Umbraco.Forms.CodeFirst.UmbracoManager.Synchronize() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\UmbracoManager.cs:32
       Umbraco.Forms.CodeFirst.UmbracoManager.SynchronizeIfNotSynchronized() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\UmbracoManager.cs:21
       Umbraco.Forms.CodeFirst.ContourFormBuilderHttpModule.context_BeginRequest(Object sender, EventArgs e) in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\ContourFormBuilderHttpModule.cs:27
       System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +80
       System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +165
  • Comment author was deleted
    Feb 27, 2013 @ 10:30
    Did you create any code first forms?
    Feb 27, 2013 @ 10:45
    Anton Oosthuizen
    Yeah I suppose it will help here it is:
    using System;
    using System.Web;
    using Umbraco.Forms.CodeFirst;
    using umbraco.cms.businesslogic.member;
    using umbraco.BusinessLogic;
    using Umbraco.Forms.Core.Providers.FieldTypes;
    using System.Web.Security;
    namespace Contour.CodeFirstExample
        public enum FormPages
            Registration
        public enum FormFieldsets
            Details
        [Form("MemberCF/Registration", ShowValidationSummary = true,MessageOnSubmit = "You are now registered! Please click on activation link sent to your email to activate your membership")]
        public class Registration : FormBase
            public const string MemberTypeAlias = "User-Member";
            public const string MemberGroupName = "Sinawe";
            [Field(FormPages.Registration, FormFieldsets.Details,
                Mandatory = true)]
            public string Name { get; set; }
                Mandatory = true)]
            public string Surname { get; set; }
                Mandatory = true,
                Regex = @"(\w[-._\w]*\w@\w[-._\w]*\w\.\w{2,3})")]
            public string Email { get; set; }
                Type = typeof(Password),
                Mandatory = true)]
            public string Password { get; set; }
                Mandatory = true)]
            public string RepeatPassword { get; set; }
            [Field(FormPages.Registration, FormFieldsets.Details,"Contact Number",
              Mandatory = true)]
            public string Contact_Number { get; set; }
              Mandatory = true)]
            public string Division { get; set; }
              Mandatory = true)]
            public string Manager { get; set; }
            //[Field(FormPages.Registration, FormFieldsets.Details,
            // Type = typeof(Umbraco.Forms.Core.Providers.FieldTypes.CheckBox))]
            //public string Newsletter { get; set; }
            public override IEnumerableValidate()
                var e = new List();
                //checks if email isn't in use
                if (Member.GetMemberFromLoginName(Email) != null)
                    e.Add(new Exception("Email already in use"));
                //makes sure the passwords are identical
                if (Password != RepeatPassword)
                    e.Add(new Exception("Passwords must match"));
                return e;
            public override void Submit()
                //get a membertype by its alias
                var mt = MemberType.GetByAlias(MemberTypeAlias); //needs to be an existing membertype
                //get the user(0)
                var user = new User(0);
                //create a new member with Member.MakeNew
                var member = Member.MakeNew(Name + Surname +"("  + Email +")" , mt, user);
                //assign email, password and loginname
                member.Email = Email;
                member.Password = Password;
                member.LoginName = Email;
                //asign custom properties
                member.getProperty("firstName").Value = Name;
                member.getProperty("lastName").Value = Surname;
                member.getProperty("contactNumber").Value = Contact_Number;
                member.getProperty("division").Value = Division;
                member.getProperty("manager").Value = Manager;
                //asssign a group, get the group by name, and assign its Id
                var group = MemberGroup.GetByName(MemberGroupName); //needs to be an existing MemberGroup
                member.AddGroup(group.Id);
                //generate the member xml with .XmlGenerate
                member.XmlGenerate(new System.Xml.XmlDocument());
                member.Save();
                //add the member to the website cache to log the member in
                //Member.AddMemberToCache(member);
                //var myUser = System.Web.Security.Membership.GetUser();
                //myUser.IsApproved = false;
    Feb 27, 2013 @ 10:59
    Ok think I might have found the issue, could you try updating the codefirst assembly to the one found here http://nightly.umbraco.org/Umbraco%20Contour/3.0.8%20WIP/ (the _update archive)
    Please let me know if that fixes the issue, thanks :)
    Feb 27, 2013 @ 16:43
    Anton Oosthuizen
    Shot!
    Feb 27, 2013 @ 16:48
    Great, thanks for confirming :)
