On my local build of Umbraco I'm getting a 404 error when I try to view any of the admin pages for Contour...
e.g. http://myumbracosite.local/umbraco/plugins/umbracoContour/editForm.aspx is throwing a resource cannot be found error.
I've confirmed the user controls are present on disk, so can't work out what I need to add in order to make sure the user control is found and rendered? Running umbraco v 4.7.2 with the 3.0.2.
Paul
Comment author was deleted
are the files present on disk, look in the \Umbraco\Plugins\umbracoContour directory to see if you have editForm.aspx, editFormEntries.aspx, ...
Hi Tim,
The files are present on disk and in the correct directory, see my initial post...
Ok maybe double check the permissions on the contour folder then
I think that's ok - same permissions as the main website running locally on my IIS, will double-check though.
Anything else? Config sections, Umbraco-specific routing etc...
Did you rename the umbraco folder?
The umbraco folder hasn't been renamed.
Yeah must be permissions then
Problem solved - reinstalling the package appeared to fix the problem.
Thanks for your help!
Regards,
404 Error in Admin Contour Sections?
Paul
Hi Tim,
Paul
Hi Tim,
Paul
Hi Tim,
Paul
Hi Tim,
Regards,
Paul
