  • joyefox 25 posts 95 karma points
    Mar 06, 2013 @ 14:57
    joyefox
    Contour code first form XPathOnSubmit setting
    Hi all,
    I'm using Contour 3.0.6 and Umbraco v4. In my code-first form I'm trying to set the XPathOnSubmit property, but when I open my form from Contour backend section no value for the property is set.
    Here is the code I'm using.
    <Form(
            "Config/MyForm",
            ManualApproval:=False,
            RequiredErrorMessage:="This field is mandatory",
            InvalidErrorMessage:="Invalid value for this field",
            XPathOnSubmit:="...my xpath..."
    Public Class MyForm
        Inherits FormBase
    End Class
    Any help will be appreciated.
    Regards
    Matteo
  • Comment author was deleted
    Mar 06, 2013 @ 15:03
    Will test and see if I get the same behaviour, will report back in a couple of mins :)
    Mar 06, 2013 @ 15:06
    Yup doesn't get set, so it's a bug
    Added issue to our tracker http://issues.umbraco.org/issue/CON-299
    Looking into fix now
    Mar 06, 2013 @ 15:11
    joyefox
    Thanks a lot Tim
    Mar 06, 2013 @ 15:14
    Fixed, was something missing in the forms code that caused the value not to be saved
    You can download the 3.0.9 WIP update archive http://nightly.umbraco.org/Umbraco%20Contour/3.0.9%20WIP/ and just deploy Umbraco.Forms.Core.DLL to fix the issue on your install (so unzip and just take the /bin/Umbraco.Forms.Core.DLL file and deploy that to the bin of you umbraco install)
    Let me know if that does the trick
    Mar 06, 2013 @ 15:51
    joyefox
    I've updated my Umbraco.Forms.CodeFirst.dll picking it from the 3.0.9. WIP update zip but I can't still see the xpath value I set on the code into the form settings page. I'm still using v3.0.6 for Umbraco.Forms.Core.dll
    Mar 06, 2013 @ 16:01
    Yeah that's because the change has been made in Umbraco.Forms.Core.DLL, sorry made a typo in the previous post
    Mar 06, 2013 @ 16:17
    joyefox
    Great, it works!
    (Thought that the right dll was CodeFirst but actually Code is closest to Core than CodeFirst ;))
    Thx
    Mar 06, 2013 @ 16:19
    Super :) glad it's working now
    Mar 06, 2013 @ 16:54
    joyefox
    Tim, now I've some problems (i.e. the form entries list page doesn't work) due to the fact that the new Umbraco.Forms.Core.dll requires System.Web.Mvc v 4.
    Unable to load one or more of the types in assembly 'Umbraco.Forms.Core, Version=3.0.8.0, Culture=neutral, PublicKeyToken=null'. Exceptions were thrown:System.IO.FileLoadException: Could not load file or assembly 'System.Web.Mvc, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
    My v4 Umbraco installation uses System.Web.Mvc v3, is it possible to get this fix working with System.Web.Mvc v3?
    Thx
    Mar 06, 2013 @ 17:25
    Yeah will provide you a patch for 3.0.6, gimme 30 mins :)
    be sure to also roll back Umbraco.Forms.CodeFirst.dll to the 3.0.6 version
    Mar 06, 2013 @ 17:29
    Mar 06, 2013 @ 18:01
    joyefox
    Ok Tim, now it's working!
    Thx
