  • Sebastian Dammark 583 posts 1407 karma points
    Mar 07, 2013 @ 15:16
    Sebastian Dammark
    Contour disappears after build
    Every time I build Contour disappears from the Sections panel.
    I have this line in my web.config 2 times:
    <add name="ContourFormBuilderHttpModule" type="Umbraco.Forms.CodeFirst.ContourFormBuilderHttpModule, Umbraco.Forms.CodeFirst" />
    I'm running Umbraco 4.9.0 and Contour 3.0.6
    What is it that I'm missing ?
  • Comment author was deleted
    Mar 07, 2013 @ 15:23
    Anything setup that resets the value in /config/applications.config and /config/trees.config ?
    Mar 07, 2013 @ 15:25
    btw those lines are for the contour code first stuff so don't think they have anything todo with it, must be something in your setup
    Mar 07, 2013 @ 15:37
    Sebastian Dammark
    Ohhh yeah ... It's definitly something in my setup.
    I just needed a pointer to where Contour added/made changes.
    Mar 07, 2013 @ 15:41
    Sebastian Dammark
    I had a post build event that copied the entire config folder.
    Thanx for great input.
    Mar 07, 2013 @ 15:53
    Great, glad it's sorted :)
