It's been mentioned to me that creating a document type with 100 properties would be quite slow to render.
How's the performance of Contour with forms containing 100+ fields?
Comment author was deleted
Contour uses a seperate datastructure and form structure is also cached so performance should still be ok
Not sure who would want to fill out a form with that many fields tho :p
Only downside is that the entries viewer migth not be that elegant to work with if you have that amount of fields
Hehe, I know. It's pretty specialist and they'll be paying for the privilage. ;-)
Thanks, Matt
Speed of large forms
Thanks, Matt
