  • Casper Stenger 1 post 21 karma points
    Mar 18, 2013 @ 14:35
    Casper Stenger
    Problem with subdomains
    Hi guys!
    I have an issue with Contour and a site with 3 different subdomains.
    The licens covers the main domain, but all the sites are accessed through the various subdomains, for example dk.domain.com, se.domain.com, no.domain.com and so on.
    The issue is this... when the user logs into Umbraco through dk.domain.com/umbraco/ and creates or edits a form, no issues. It all works as intended.
    If he then later logs in through se.domain.com, he´s still able to see the form in the Contour panel, but it doesn´t show any fields in the design overview for that form. Log in again through the subdomain, where he originally created the form, and all fields show. Anyone ever experienced empty fields in forms, when logging in via different subdomains?
    I know we can always just log in through the same domain, but we´re experiencing some caching issues, whichdoesn´t make it feasible, if we want to see the results frontend straight away, hence the different login URL´s.
    Umbraco: 4.7.2
    Contour 3.0.6
    Thanks for any help,
    Casper
  • Comment author was deleted
    Mar 18, 2013 @ 14:38
    How is your license setup? If you did it correcly so set it up for domain.com it should just work for all subdomains.
    If you shoot me an email on tg at umbraco dot com with your umbraco.com account details I can update the license for you
    Tim
