I deleted all conditions on a field but left the enable conditions box ticked and saved the form. The form now falls over when I hit the step I made that amendment in, with the error
Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index
So I added the conditions back into the field but that hasn't fixed the issue, Iv'e tried deleting the field but the sql is blocked due to a foreign key constraints on UFFieldConditionRules to UFFields.
I can't seem to get any stack trace from this error so I'm a bit stumped as to what to do next (nothing in umbracoLog table or /App_Data/Logs/UmbracoTraceLog.txt and nothing shown with umbDebugShowTrace=true on the page).
Before I start unpicking my form and removing conditions so I can delete what I assume is the offending field does anyone have any ideas?
In the DB I seem to have three conditions still against the field but I'm not sure I'm running the right query to find out.
select * from uffieldconditionrules where fieldcondition = (SELECT id FROM UFFieldConditions where field like 'c207af05%')
That SQL return three entries which were the original conditions before I deleted them and at the point of running that query there are no conditions and conditions are disabled on the field.
Can you confirm that given a field Id the above SQL will show you associated conditions, I don't want to start deleting things directly out of the database unless I'm sure.
Just to let you know, I've tidied up the DB and its not fixed the issue and I've been unable to replicate the problem on a test form so I think the conditions thing may be a red herring. I'll try and get to the bottom of the issue and let you know anything I find but you can probably remove the issue tracker item for now.
Error: Index was out of range.
Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: indexSo I added the conditions back into the field but that hasn't fixed the issue, Iv'e tried deleting the field but the sql is blocked due to a foreign key constraints on UFFieldConditionRules to UFFields.
Simon
Comment author was deleted
And what happens if you disable the conditions on that field?
Exactly the same error.
Thanks for your help
Simon
Ok will add this to our issue tracker, thanks for reporting
Many thanks
Simon
:edited for spelling
Yup I can confirm that :)
Hi Tim,
Simon
Ok thanks Simon, I'll also see if I can reproduce it
