  • Fabiano 12 posts 32 karma points
    Mar 22, 2013 @ 14:02
    Fabiano
    Radio Button Validation not working properly
    I am using Umbraco 4.7.2 with Contour installed. Contour version is 3.0.0 and it appears that the validation for the radio button does not work correctly. it allows the user to select only the first radio button if the user select a diffrent radio button (not the firstvradio button)  witinh the same question a validation error appears say that the field is not selected.
    Do you have any ida why this is happening?
    Any help would be appreciated.
    Fabiano
