Contour adds whitespaces before Razor macro which mess up layout
I'm having very annoying white spaces on top of the form if I include it in razor. This way the HTML layout is not the way I want it to, it shows an extra whitespace line.
I've tested it with a clean install of Umbraco 4.11.5 and Umbraco Contour 3.0.9 and it still shows there.
These are the steps to reproduce it:
1. Create a new Contour form (default Contact form) 2. Disable umbraco stylesheets 3. Add correct JS files to the template 4. Add a paragraph in the content 5. Add the RAZOR script underneath and add the form
See this screenshot, for clarity i've added a margin and padding of 0 to show the whitespace. See the yellow marked parts.
If I remove the whitespaces using Chrome Dev Tools the form is showed correctly without extra whitespace.
I think this is a bug and I've posted this as a bug to the Contour team, but maybe somebody has a different solution for me?
We are seeing exactly the same issue, does anyone have a solution? Does this need to be posted to Contour customer support?
Maybe you should post it also to the Contour customer support, I've submitted a bug using the website, but did not get any reply yet.
Comment author was deleted
Pushed a fix to 3.0.10 WIP , you can download it here http://nightly.umbraco.org/Umbraco%20Contour/3.0.10%20WIP/
Upgrade instructions here http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Upgrade
Final 3.0.10 release will be out May 1st
