Form fields losing values when clicking on previous
I am finding that certain Contour form fields are losing their values when i go back in the form by clicking on Previous. This seems to happen with dropdown lists and date fields.
Also, the date fields revert to US date format (instead of UK) when you click on Previous/Back.
We are running umbraco v 4.11.4 (Assembly version: 1.0.4780.19111), with Contour 3.0.7
Sorry, I just found out we have already patched to that level (the version number doesnt update in the Installed packages directory), but we are still experiencing both problems.
I've just tested this in Contour 3.0.9 and both the dropdown and date field hold the date when moving between pages, tested in Chrome and Internet explorer
Do you have any more details on how to reproduce the issue?
It would be easier if I send you a link to the form itself, but it's not something I can share publicly. Would it be possible for you to email me at claireh@systemassociates.co.uk and I will forward you the links to forms where this occurs?
Any ideas?
Claire
Comment author was deleted
Hi Claire,
I would suggest that you upgrade to 3.0.9 details can be found here http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Upgrade
That should definitly resolve the issue with the dropdown list, will take a look at the other issues
Hi Tim
Claire
Ok will add the issues to our tracker and these issues will be resolved for the next maintenance release that will go out next week
Regards,
Tim
Link to the issues:
http://issues.umbraco.org/issue/CON-316
http://issues.umbraco.org/issue/CON-317
Great stuff, thank you! How will I find out when the patch is released?
Sorry for the delay, looking into this today
Tim
Hi Claire,
Hi Tim
Many thanks
Claire
Ok you've got mail :)
