  • MK 429 posts 906 karma points
    Mar 27, 2013 @ 20:04
    MK
    Condition part is empty
    Hi there,
    Trying to enable the condition for one of my textboxes and for some reason I canot see the Condition statment.
    Any Idea?
    mkariti
  • Comment author was deleted
    Mar 29, 2013 @ 11:22
    Hmm that's strange, what version of Contour are you running?
    Mar 29, 2013 @ 11:23
    MK
    3.0.9 But ive upgraded it from 2 - also upgraded my umbraco from 4.7.1 to 4.11.5....
    Mar 29, 2013 @ 11:27
    Maybe missing file when you did the upgrade, could you try doing the upgrade again
    Details here: http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Upgrade
    Mar 29, 2013 @ 11:30
    MK
    Ok will give it a try.
    Mar 29, 2013 @ 15:25
    MK
    Ok just finished reinstall contour and It seems like im facing my last bug for today.
    I used to use the RecordService_RecordSubmitted event to get the form values via e.Form.AllFields[0].Values[0].ToString().
    I know its not clean but it did the job. anyway, now all values are empty. Can it be becos im using razor?
    Also, the entries section seems fine.
    cheers
    mkariti
    Mar 29, 2013 @ 15:40
    MK
    e.Record.GetRecordField("Loginname").Values[0]; DONE!
