Contour textfield and textarea not allowing any placeholder to be inserted
Not really sure what's the issue with both textfield and textarea for contour as I'm not able to add in the placehilder part inside. It keeps removing the text written.
I'd like to extend the initial query if possible and ask how you would insert the ToolTip text as the placeholder? I have tried the following but this doesn't work:
Code as follow
Results shown
<input type="email" placeholder="" name="d1300ea1-277d-40e0-bef4-2d44004c8f30" class="input-clear margin_b_10" data-val="true" data-val-regex="Your Email is not valid" data-regex="^[_a-z0-9-]+(\.[_a-z0-9-]+)*@[a-z0-9-]+(\.[a-z0-9-]+)*(\.[a-z]{2,4})$">The placeholder part seems to emptied out. Appreciate any help
thanks
Comment author was deleted
Just tested and it works fine, are you sure you are updating the correct view?
Yup updating the correct view
That's strange, and nothing else in place that might be causing the behaviour
Any chance I can take a look at the site, you can mail details to tg at umbraco dot com
Hey tim, seems to find out about the issue. It's caused by other API affecting contour.
Thanks for all the help too
<input type="text" name="@Model.Name" id="@Model.Id" class="text" value="@Model.Value" maxlength="200" placeholder="@Model.ToolTip" @{if(Model.Mandatory || Model.Validate){<text>data-val="true"</text>}} @{if (Model.Mandatory) {<text> data-val-required="@Model.RequiredErrorMessage"</text>}} @{if (Model.Validate) {<text> data-val-regex="@Model.InvalidErrorMessage" data-regex="@Html.Raw(Model.Regex)"</text>}} />is working on a reply...
