Hi there,
The following code works fine in debug mode but not in release mode:
if (e.Form.Id == new Guid("b62ffdb4-1620-44a6-8859-465f36b75b89")) { e.Record.GetRecordField("CategoryId").Values.Clear(); e.Record.GetRecordField("CategoryId").Values.Add(Node.GetCurrent().Id); e.Record.GetRecordField("NodeName").Values.Clear(); e.Record.GetRecordField("NodeName").Values.Add(DateTime.Now.ToString()); e.Record.GetRecordField("CategoryName").Values.Add(Node.GetCurrent().Name); RecordStorage rs = new RecordStorage(); rs.UpdateRecord(e.Record, e.Form); rs.UpdateRecordXml(e.Record, e.Form); rs.Dispose(); }
Any Idea why it behaves like that?
Cheers
mkariti
Ok so it seems that its nothing to do with the mode.
For some reason the code will not work on the production server....!?
Comment author was deleted
Does the form have the same GUID on the prod server
Yes the same!
And it has the same fields ? Added to the same workflow step?
Yes - ive uploaded my local site to production including the DB so they are identical
Ok Im getting strage error now when tring to create new form:
Description: An unhandled exception occurred
Any idea?
Hmm sure all the files are uploaded
Contour release mode problem
Hi there,
if (e.Form.Id == new Guid("b62ffdb4-1620-44a6-8859-465f36b75b89")) { e.Record.GetRecordField("CategoryId").Values.Clear(); e.Record.GetRecordField("CategoryId").Values.Add(Node.GetCurrent().Id); e.Record.GetRecordField("NodeName").Values.Clear(); e.Record.GetRecordField("NodeName").Values.Add(DateTime.Now.ToString()); e.Record.GetRecordField("CategoryName").Values.Add(Node.GetCurrent().Name); RecordStorage rs = new RecordStorage(); rs.UpdateRecord(e.Record, e.Form); rs.UpdateRecordXml(e.Record, e.Form); rs.Dispose(); }Any Idea why it behaves like that?
Cheers
mkariti
Yes the same!
Method not found: 'Umbraco.Forms.Core.Form Umbraco.Forms.Data.Storage.FormStorage.InsertForm(Umbraco.Forms.Core.Form)'.
Any idea?
