jQuery Mobile and AltTemplate not loading Contour form
As the title states, I am using a mobile AltTemplate and jquery mobile. The whole site loads and works, except for one page. The one with the Contour form on it. IT just hangs with the spinning wheel loading icon and never loads the page. Is there some way to force the contour form to load as ajax through the jquery mobile. Or, worst case scenerio, is there a way in my content editor, to put a conditional statement around the inserted macro to not load if the URL has the word mobile in it? That way at least a portion of the page will load, and it won't just hang.
I have had this same thing happen to me, it can be a couple of things but as you are not getting anything my gut would be it is because Contour forms require a <form runat="server">xyz </form> around the form and your JQM/mobile template does not contan one and as such the page throws an error (when that happens JQM just hangs)
To test just append the ?alttemplate=mobilexyz to the page with the form and see if it works at all.
If it does work then this is likely to be an issue with how JQM by loads content using ajax by default meaning forms etc don't always work however I would expect you to see something if that was the case.
I see the form, if I load the page directly, but not when I am using the jquery select navigation bar. So, i edited my code to take the form page out of the drop down, and used a simple button, and it loads the page. So, I guess it is related to that. But on a related note, I tried submitting the form, and it hangs on the loading symbol and never submits.
If possible can you send me a link or the html of the form page (gavstorey at gmail.com), but I would try disabling JQM ajax loading to see if that fixes the issue to do that add the following to the link (disables ajax on that link only) :
<a href="my link to form" rel="external">link</a>
or
<a href="my link to form" data-ajax="false">link</a>
or add data-ajax="false" to the parent container of the link:
<div data-ajax="false"><a href="my link to form">link</a></div>
or
