Looking at contour for a specific application.
I know we can have conditions based on an answer but can contour do the following scenario?
If yes is selected then I need the user to fill in four bits of info..
Parent Name | Parent registered number | Country of Parent | % of Subsiduary owned by Parent
In addition to this i need to give the user the ability to add mutliple's of this info...is this doable OTB?
S
Comment author was deleted
Displaying 4 bits depending on a condition is possible, but for the multiples you'll need to add some custom stuff
Thanks Tim.
Conditionally display more info in multiples?
S
Thanks Tim.
