  • Richard Barg 358 posts 532 karma points
    Apr 08, 2013 @ 17:13
    Richard Barg
    Feature Request - Ability to reorder checkboxes & radio buttons
    This is a feature request I put in.  Posting here to see how much interest there is:
    CON-325 Radio Buttons and Checkboxes Cannot Be Reordered witin Field- All must be deleted and reinputted to change
    Issue is visible to:
    This is a feature request. If you want to add a radio button or checkbox and keep them in fixed order, ie alphabetical, you have to delete the entire series and start over. It would be great to be able to recorder them.
    An example is shown below. You can see how cumbersome this is to add a new board as a middle element in the list:
  • Comment author was deleted
    Apr 09, 2013 @ 11:18
    Yeah makes sense, won't be that hard to add so assigning it to vnext 3.0.10
    Apr 25, 2013 @ 11:13
    Will be part of 3.0.10 :) http://www.screenr.com/fN57
