I want to add an "error" class to my markup whenever a field is invalid. In the Form.cshtml file I have the field foreach loop, and access to a lot of information. Only thing I cant find is a property or something to show me if the field is actually invalid. The validation message is written like this by standard:
Razor check if field is valid
Hi Guys,
@if (Model.ShowFieldValidaton){@Html.ValidationMessage(f.Id)}
That's the only place that a "real" validation is made and it's kind of cheat, as it just returns som html.
Can I somehow get a true/false instead?
/Rune
Comment author was deleted
Hmm maybe it's better to look into adding this to the jquery validate stuff, think that has some hooks you can use
Or try to access ModelState["Name"].Errors.Count() > 0
Hi Tim,
There's no ModelState in Form.cshtml. Problem is that the FieldViewModel object contains no information about errors.
About the jQuery Validate plugin, it would work without hooks or anything if I could:
1. Add a required="required" attribute to the fields
2. Add an "error" class to the field if it does not validate correctly
Both should be done serverside, but I can't figure out what FieldViewModel properties I should use.
/Rune
Ok will check what I can do about that
Hi Rune,
Just tested and you should be able to use
in fieldtype view:
@if (ViewData.ModelState[Model.Name] != null)
@ViewData.ModelState[Model.Name].Errors.Count()
in form view (field loop)
if (ViewData.ModelState[f.Name] != null)
@ViewData.ModelState[f.Name].Errors.Count()
Perfect. That worked just like I wanted it.
Thanks a lot Tim.
/Rune
Great :)
