  • Simon Napper 116 posts 370 karma points
    Apr 12, 2013 @ 12:49
    Simon Napper
    Codefirst CheckBoxList and prevalues seem to need a comma in the array element?
    Hi all,
    I came across a strange problem the other day that I'm hoping is something that I've missed rather than a bug in Contour, so perhaps one of you lovely people could let me know!  I'm creating a checkboxlist on a codefirst contour page, however I found that if I don't have a comma within the value entered into the array for the prevalues, that I get a:
    Object of type 'System.String' cannot be converted to type 'System.Collections.Generic.List`1[System.String]'
    error, however if I add a comma to the text in the array it works fine.  To show you what I mean, the first code block below causes the error:
    [Field(FormPages.Callout,
                   FormFieldsets.Signup,
                   Type = typeof(CheckBoxList),
                   Prevalues = new[] { "Yes", "No" })]
            public List<string> Member { get; set; }
    However this one is fine, notice the addition of an extra comma after Yes and No:
                   Prevalues = new[] { "Yes,", "No," })]
    Anyone able to shed some light on this or suggest an alternative approach?
    Many Thanks.
  • Comment author was deleted
    Apr 15, 2013 @ 09:59
    Hmm that's strange, will give it a try
    Apr 15, 2013 @ 10:08
    Hi Simon,
    Just tested and it should work without the extra comma
    When exactly are you getting the error, could you post a stacktrace
    I tried created a new form code first with your example and that works...
    Apr 15, 2013 @ 17:02
    Simon Napper
    Hi Tim,
    Thanks for getting back so promptly.  Here's the stacktrace from the detail of the exception, if you need anything else then please feel free to ask!
       at System.RuntimeType.TryChangeType(Object value, Binder binder, CultureInfo culture, Boolean needsSpecialCast)
      at System.Reflection.MethodBase.CheckArguments(Object[] parameters, Binder binder, BindingFlags invokeAttr, CultureInfo culture, Signature sig)
       at System.Reflection.RuntimeMethodInfo.InvokeArgumentsCheck(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
       at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
       at System.Reflection.RuntimePropertyInfo.SetValue(Object obj, Object value, Object[] index)
       at Umbraco.Forms.CodeFirst.FormManager.CreateFormBaseInstance(FormViewEventArgs e) in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\FormBuilder\FormManager.cs:line 187
       at Umbraco.Forms.CodeFirst.FormManager.FormRenderController_FormValidate(Object sender, FormViewEventArgs e) in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\FormBuilder\FormManager.cs:line 33
       at Umbraco.Forms.Mvc.Controllers.FormRenderController.ContourForm(FormViewModel model, Boolean captchaIsValid) in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.Mvc\Controllers\FormRenderController.cs:line 178
       at lambda_method(Closure , ControllerBase , Object[] )
       at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters)
       at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters)
       at System.Web.Mvc.ControllerActionInvoker.<>c__DisplayClass13.<InvokeActionMethodWithFilters>b__10()
       at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation)
    Thanks in advance!
    Simon
    Apr 15, 2013 @ 17:16
    Looks like it is happening in the validate method, so might be a bug there, checking it out now
    Apr 15, 2013 @ 17:20
    Ok can confirm that it's a bug, happens when you only select 1 item in the checkboxlist
    Apr 15, 2013 @ 17:21
    Added to our issue tracker http://issues.umbraco.org/issue/CON-331 will try to have a fix this week
    Apr 15, 2013 @ 17:26
    Simon Napper
    Thanks Tim, will keep my eyes peeled for the fix!
    Apr 15, 2013 @ 17:34
    Ok think I found a fix :)
    Could you try downloading http://nightly.umbraco.org/Umbraco%20Contour/3.0.10%20WIP/
    UmbracoContour_3.0.10 WIP_update.zip
    And you'll just need to deploy Umbraco.Forms.CodeFirst.dll to your bin directory
    Let me know if that fixes the issue for you
    Tim
    Apr 16, 2013 @ 15:18
    Simon Napper
    Hi Tim,
    That's perfect, works like a treat now!  Thanks for your help with this.
    Simon
    Apr 16, 2013 @ 16:14
    Great, thanks for confirming!
