  • Mike 81 posts 101 karma points
    Apr 13, 2013 @ 06:26
    Mike
    contour install issues continue
    Got the site back up by adding in the missing mvc.dll.
    Go to install it again and I get this error -
    An item with the same key has already been added
    Seems there's already a file with the same name that throws this erro.
    Any suggestions
  • Comment author was deleted
    Apr 15, 2013 @ 10:22
    Hey Mike,
    What Umbraco version are you running, if the mvc dll was missing you must be running an older version and in that case it might be best to also install an older version of Contour
    Apr 21, 2013 @ 18:40
    Mike
    I'm running umbraco v 4.9.0
    Which version of countour should I be downloading?
    Apr 21, 2013 @ 18:43
    Mike
    I was following the documentation by downloading from the developer section inside the umbraco instance at this URL
    http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Installation
    Can you direct me to the proper install instructions?
    Apr 21, 2013 @ 18:56
    Mike
    Okay, I found some more documentation. I uninstalled what was in there. Downloaded 3.09 and redoing the install.
