Attachment missed when not filling mandatory field
Hi, I have a contour form that have several fields, one of the fields is an attachment field and other that is a mandatory checkbox that have to be filled in order to submit the form.
If i attach a document and do not check the mandatory checkbox and hit submit then i got a error message (which stands that you have to check the checkbox) but then i have to look for the attachment again.
I would really like not to look for the atachment again if i miss to check the mandatory field.
I would suggest that you use the razor version of the macro that handles the validation of the checkbox client side and shouldn't lose the selected file
Any thing i can try?
Comment author was deleted
Hi Sergio, are you using the razor or usercontrol macro?
I am attaching the contour form directly in a rich text box that later will be used in the page...
Like this http://screencast.com/t/tSDSqAUu7AJ9
Ok and could you tell me wich Contour macro you used (there are 2 ones, one using a usercontrol and the other using razor)
Tim
We are using this umb_macroalias="umbracoContour.RenderForm"
Hey Sergio,
