    Apr 19, 2013 @ 12:04
    Dirk De Grave
    "Required Error Message" in designer and settings
    Simple question: what's the diff between marking a field as mandatory and specifying a "Required error message" (set to #ContactFormNameRequired as dict item and has been created) in 'Designer' (so for a field individually) and specifying a "Required error message" on the "Validation" group in Settings tab?
    Seems to use the latter even tho i've specified one for a field specifically?
    Haven't customized form nor field!
    Any ideas?
    (using latest v3.0.9 version)
    /Dirk
  • Comment author was deleted
    Apr 19, 2013 @ 16:20
    Yeah it should use the field one if that is setup, will see if I can repro
    Apr 19, 2013 @ 16:35
    Just tested and it works like expected,
    Setup the Required error message on the field and it will show that instead of the one set on form level...
    Apr 19, 2013 @ 16:38
    Or did I misunderstand the question?
    Apr 22, 2013 @ 17:44
    Dirk De Grave
    Yup, works as expected after having added jquery validation scripts #h5is
    /Dirk
    Apr 23, 2013 @ 09:17
    Looks like it's a bug with the server side validation message
    http://issues.umbraco.org/issue/CON-340
    Will be fixed in 3.0.10 (out in a couple of days)
    Apr 23, 2013 @ 09:25
    Fixed, logic wasn't correct (so field message was never used unless the form one was empty)
