I'm in one of those projects at the momment where everything I want to do requires something building that there isn't quite a full functional example for. To that end I pressent for your consideration a working example of a custom fieldtype for upload to Umbraco media. It's formed from code in other examples on media creation wrapped up into a Umbraco fieldtype but hopefully having it here on the forum will save a little searching for someone else =)
using System;
using System.IO;
using System.Drawing;
using System.Drawing.Drawing2D;
using System.Drawing.Imaging;
using System.Linq;
using System.Text;
using System.Text.RegularExpressions;
using System.Web;
using System.Web.UI.WebControls;
using Umbraco.Core;
using Umbraco.Core.Models;
using Umbraco.Core.Services;
using Umbraco.Forms.Data;
using Umbraco.Forms.Core;
using Umbraco.Forms.Core.Controls;
namespace Umbraco.Extensions.Forms
public class uploadMedia : FieldType
//[Umbraco.Forms.Core.Attributes.Setting("Upload extensions",
//description = "Allowed file extensions",
//control = "Umbraco.Forms.Core.FieldSetting.TextField")]
//public string AllowedExtensions { get; set; }
//[Umbraco.Forms.Core.Attributes.Setting("Media Parent ID",
//description = "ID of the parent where the media will be saved",
//public string MediaParentId { get; set; }
public uploadMedia()
//Provider
this.Id = new Guid("xxx-xxx-xxx-xxx-xxx");
this.Name = "Upload Media";
this.Description = "Upload file to Umbraco Media";
//FieldType
this.Icon = "textfield.png";
this.DataType = FieldDataType.String;
public override string RenderPreview()
return "<input type='file'/>";
public override string RenderPreviewWithPrevalues(List<object> prevalues)
return RenderPreview();
public override List<object> ProcessValue(HttpContextBase httpContext)
List<Object> vals = new List<object>();
//files
var ms = ApplicationContext.Current.Services.MediaService;
var cts = ApplicationContext.Current.Services.ContentTypeService;
bool filesaved = false;
string _text;
string mediaPath = "";
Media m = null;
var files = httpContext.Request.Files;
if (files.Count > 0 && files.AllKeys.Contains(this.AssociatedField.Id.ToString()))
HttpPostedFileBase file = null;
file = files[this.AssociatedField.Id.ToString()];
if (file.ContentLength > 0)
if (file.FileName != "")
// Find filename
_text = file.FileName;
string filename;
string _fullFilePath;
filename = _text.Substring(_text.LastIndexOf("\\") + 1, _text.Length - _text.LastIndexOf("\\") - 1).ToLower();
// create the Media Node
// TODO: get parent id for current category - as selected by user (see below)
// - for now just stick these in the media root :: node = -1
var mediaType = cts.GetMediaType(1224);
m = new Media(
filename, 1189, mediaType);
ms.Save(m);
// Create a new folder in the /media folder with the name /media/propertyid
string mediaRootPath = "~/media/"; // get path from App_GlobalResources
string storagePath = mediaRootPath + m.Id.ToString();
if (!System.IO.Directory.Exists(HttpContext.Current.Server.MapPath(storagePath)))
System.IO.Directory.CreateDirectory(HttpContext.Current.Server.MapPath(storagePath));
_fullFilePath = HttpContext.Current.Server.MapPath(storagePath) + "\\" + filename;
file.SaveAs(_fullFilePath);
// Save extension
string orgExt = ((string)_text.Substring(_text.LastIndexOf(".") + 1, _text.Length - _text.LastIndexOf(".") - 1));
orgExt = orgExt.ToLower();
string ext = orgExt.ToLower();
try
m.SetValue("umbracoExtension", ext);
catch { }
// Save file size
try
System.IO.FileInfo fi = new System.IO.FileInfo(_fullFilePath);
m.SetValue("umbracoBytes", fi.Length.ToString());
catch { }
// Check if image and then get sizes, make thumb and update database
if (",jpeg,jpg,gif,bmp,png,tiff,tif,".IndexOf("," + ext + ",") > 0)
int fileWidth;
int fileHeight;
FileStream fs = new FileStream(_fullFilePath,
FileMode.Open, FileAccess.Read, FileShare.Read);
System.Drawing.Image image = System.Drawing.Image.FromStream(fs);
fileWidth = image.Width;
fileHeight = image.Height;
fs.Close();
try
m.SetValue("umbracoWidth", fileWidth.ToString());
m.SetValue("umbracoHeight", fileHeight.ToString());
catch { }
// Generate thumbnails
string fileNameThumb = _fullFilePath.Replace("." + orgExt, "_thumb");
generateThumbnail(image, 100, fileWidth, fileHeight, _fullFilePath, ext, fileNameThumb + ".jpg");
image.Dispose();
mediaPath = "/media/" + m.Id.ToString() + "/" + filename;
m.SetValue("umbracoFile", mediaPath);
ms.Save(m);
vals.Add(filename);
filesaved = true;
if (!filesaved)
vals.Add("No file saved");
return vals;
protected void generateThumbnail(System.Drawing.Image image, int maxWidthHeight, int fileWidth, int fileHeight, string fullFilePath, string ext, string thumbnailFileName)
float fx = (float)fileWidth / (float)maxWidthHeight;
float fy = (float)fileHeight / (float)maxWidthHeight;
// must fit in thumbnail size
float f = Math.Max(fx, fy); //if (f < 1) f = 1;
int widthTh = (int)Math.Round((float)fileWidth / f); int heightTh = (int)Math.Round((float)fileHeight / f);
// fixes for empty width or height
if (widthTh == 0)
widthTh = 1;
if (heightTh == 0)
heightTh = 1;
// Create new image with best quality settings
Bitmap bp = new Bitmap(widthTh, heightTh);
Graphics g = Graphics.FromImage(bp);
g.SmoothingMode = SmoothingMode.HighQuality;
g.InterpolationMode = InterpolationMode.HighQualityBicubic;
g.PixelOffsetMode = PixelOffsetMode.HighQuality;
// Copy the old image to the new and resized
Rectangle rect = new Rectangle(0, 0, widthTh, heightTh);
g.DrawImage(image, rect, 0, 0, image.Width, image.Height, GraphicsUnit.Pixel);
// Copy metadata
ImageCodecInfo[] codecs = ImageCodecInfo.GetImageEncoders();
ImageCodecInfo codec = null;
for (int i = 0; i < codecs.Length; i++)
if (codecs[i].MimeType.Equals("image/jpeg"))
codec = codecs[i];
// Set compresion ratio to 90%
EncoderParameters ep = new EncoderParameters();
ep.Param[0] = new EncoderParameter(System.Drawing.Imaging.Encoder.Quality, 90L);
// Save the new image
bp.Save(thumbnailFileName, codec, ep);
bp.Dispose();
g.Dispose();
Upload to Media custom FieldType - example
Hi everyone,
using System; using System.IO; using System.Drawing; using System.Drawing.Drawing2D; using System.Drawing.Imaging; using System.Collections.Generic; using System.Linq; using System.Text; using System.Text.RegularExpressions; using System.Web; using System.Web.UI.WebControls; using Umbraco.Core; using Umbraco.Core.Models; using Umbraco.Core.Services; using Umbraco.Forms.Data; using Umbraco.Forms.Core; using Umbraco.Forms.Core.Controls; namespace Umbraco.Extensions.Forms { public class uploadMedia : FieldType { //[Umbraco.Forms.Core.Attributes.Setting("Upload extensions", //description = "Allowed file extensions", //control = "Umbraco.Forms.Core.FieldSetting.TextField")] //public string AllowedExtensions { get; set; } //[Umbraco.Forms.Core.Attributes.Setting("Media Parent ID", //description = "ID of the parent where the media will be saved", //control = "Umbraco.Forms.Core.FieldSetting.TextField")] //public string MediaParentId { get; set; } public uploadMedia() { //Provider this.Id = new Guid("xxx-xxx-xxx-xxx-xxx"); this.Name = "Upload Media"; this.Description = "Upload file to Umbraco Media"; //FieldType this.Icon = "textfield.png"; this.DataType = FieldDataType.String; } public override string RenderPreview() { return "<input type='file'/>"; } public override string RenderPreviewWithPrevalues(List<object> prevalues) { return RenderPreview(); } public override List<object> ProcessValue(HttpContextBase httpContext) { List<Object> vals = new List<object>(); //files var ms = ApplicationContext.Current.Services.MediaService; var cts = ApplicationContext.Current.Services.ContentTypeService; bool filesaved = false; string _text; string mediaPath = ""; Media m = null; var files = httpContext.Request.Files; if (files.Count > 0 && files.AllKeys.Contains(this.AssociatedField.Id.ToString())) { HttpPostedFileBase file = null; file = files[this.AssociatedField.Id.ToString()]; if (file.ContentLength > 0) { if (file.FileName != "") { // Find filename _text = file.FileName; string filename; string _fullFilePath; filename = _text.Substring(_text.LastIndexOf("\\") + 1, _text.Length - _text.LastIndexOf("\\") - 1).ToLower(); // create the Media Node // TODO: get parent id for current category - as selected by user (see below) // - for now just stick these in the media root :: node = -1 var mediaType = cts.GetMediaType(1224); m = new Media( filename, 1189, mediaType); ms.Save(m); // Create a new folder in the /media folder with the name /media/propertyid string mediaRootPath = "~/media/"; // get path from App_GlobalResources string storagePath = mediaRootPath + m.Id.ToString(); if (!System.IO.Directory.Exists(HttpContext.Current.Server.MapPath(storagePath))) System.IO.Directory.CreateDirectory(HttpContext.Current.Server.MapPath(storagePath)); _fullFilePath = HttpContext.Current.Server.MapPath(storagePath) + "\\" + filename; file.SaveAs(_fullFilePath); // Save extension string orgExt = ((string)_text.Substring(_text.LastIndexOf(".") + 1, _text.Length - _text.LastIndexOf(".") - 1)); orgExt = orgExt.ToLower(); string ext = orgExt.ToLower(); try { m.SetValue("umbracoExtension", ext); } catch { } // Save file size try { System.IO.FileInfo fi = new System.IO.FileInfo(_fullFilePath); m.SetValue("umbracoBytes", fi.Length.ToString()); } catch { } // Check if image and then get sizes, make thumb and update database if (",jpeg,jpg,gif,bmp,png,tiff,tif,".IndexOf("," + ext + ",") > 0) { int fileWidth; int fileHeight; FileStream fs = new FileStream(_fullFilePath, FileMode.Open, FileAccess.Read, FileShare.Read); System.Drawing.Image image = System.Drawing.Image.FromStream(fs); fileWidth = image.Width; fileHeight = image.Height; fs.Close(); try { m.SetValue("umbracoWidth", fileWidth.ToString()); m.SetValue("umbracoHeight", fileHeight.ToString()); } catch { } // Generate thumbnails string fileNameThumb = _fullFilePath.Replace("." + orgExt, "_thumb"); generateThumbnail(image, 100, fileWidth, fileHeight, _fullFilePath, ext, fileNameThumb + ".jpg"); image.Dispose(); } mediaPath = "/media/" + m.Id.ToString() + "/" + filename; m.SetValue("umbracoFile", mediaPath); ms.Save(m); vals.Add(filename); filesaved = true; } } } if (!filesaved) { vals.Add("No file saved"); } return vals; } protected void generateThumbnail(System.Drawing.Image image, int maxWidthHeight, int fileWidth, int fileHeight, string fullFilePath, string ext, string thumbnailFileName) { // Generate thumbnail float fx = (float)fileWidth / (float)maxWidthHeight; float fy = (float)fileHeight / (float)maxWidthHeight; // must fit in thumbnail size float f = Math.Max(fx, fy); //if (f < 1) f = 1; int widthTh = (int)Math.Round((float)fileWidth / f); int heightTh = (int)Math.Round((float)fileHeight / f); // fixes for empty width or height if (widthTh == 0) widthTh = 1; if (heightTh == 0) heightTh = 1; // Create new image with best quality settings Bitmap bp = new Bitmap(widthTh, heightTh); Graphics g = Graphics.FromImage(bp); g.SmoothingMode = SmoothingMode.HighQuality; g.InterpolationMode = InterpolationMode.HighQualityBicubic; g.PixelOffsetMode = PixelOffsetMode.HighQuality; // Copy the old image to the new and resized Rectangle rect = new Rectangle(0, 0, widthTh, heightTh); g.DrawImage(image, rect, 0, 0, image.Width, image.Height, GraphicsUnit.Pixel); // Copy metadata ImageCodecInfo[] codecs = ImageCodecInfo.GetImageEncoders(); ImageCodecInfo codec = null; for (int i = 0; i < codecs.Length; i++) { if (codecs[i].MimeType.Equals("image/jpeg")) codec = codecs[i]; } // Set compresion ratio to 90% EncoderParameters ep = new EncoderParameters(); ep.Param[0] = new EncoderParameter(System.Drawing.Imaging.Encoder.Quality, 90L); // Save the new image bp.Save(thumbnailFileName, codec, ep); bp.Dispose(); g.Dispose(); } } }Umbraco 6.0.3 MVC - Contour 3.0.10
