When you see this form:
http://thy360.dk/branding-af-thy/vind-en-ipad.aspx
The text above the checkboxes contain Danish letters but they are for some reason removed.
The site is set as a Danish language site.
When I access the form from the admin it is displayed correctly.
Comment author was deleted
Hmm seems do an update in the latest version, update coming today that fixes this
Found and fixed, update coming within the hour
Ok version 3.0.11 is available fixing this bug and the checkbox one
Upgrade instructions available here: http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Upgrade
If you are currently on 3.0.10 the only changes have been in the
\Umbraco\Plugins\umbracoContour\Views\Form.cshtml and \Umbraco\Plugins\umbracoContour\Views\FieldType.CheckBox.cshtml files so you'll just need to deploy those from the upgrade archive
http://our.umbraco.org//forum/umbraco-pro/contour/40612-Contour-3011-changes
Danish letters removed from label
