Topic author was deleted
May 02, 2013 @ 10:53
Contour 3.0.11 changes
Contour 3.0.11 is out mainly because of issue http://issues.umbraco.org/issue/CON-353 (some chars get removed from page/fieldset/field labels in the form render)
3.0.11 - May 2013
Fixed: CON-354 Setting default value on checkbox doesn't have any effect Fixed: CON-353 Danish letters removed from label
If you are currently on 3.0.10 the only changes have been in the
\Umbraco\Plugins\umbracoContour\Views\Form.cshtml and \Umbraco\Plugins\umbracoContour\Views\FieldType.CheckBox.cshtml files so you'll just need to deploy those from the upgrade archive
I am using version 3.0.9 but encounter another issue. I am trying to display two fields that are related to each other because thier condition depend on the first field in the question. Basically:
1. I have Q1 which is a drop down list with two values: Yes and No;
2. Q2 has four fields: test 2, test 2 conditional, test 2 conditional #3 and test text. test 2 and test text will appear if Q1 is No, instead test 2 conditional and test 2 conditional #3 will appear depending on the user ticks in test 2. At the moment test 2 conditional appears when the user ticks any of the checkboxes (1 and/or 2 and/or 3 ...) whereas test 2 conditional #3 appears only if the user ticks 1 and/or 4. Everything seemed to work fine but the condition broke only when the user ticks on the value 1 ( in this case both test 2 conditional and test 2 conditional #3 should be displayed). I debugged the javascript file in Chrome and it appears that the condition is not working because of the condition set on test 2. In fact if I take off the condition on test 2 everything works fine.
Do you think upgrading to 3.0.11 would solve this issue? or is there a way to access the javascript file locally?
3.0.11 - May 2013
Upgrade instructions available here: http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Upgrade
Hello Tim,
Any further question please ask.
Any help would be appreciated.
Fabiano
Comment author was deleted
Ok will take a look, upgrading to 3.0.11 won't do anything since there has been no changes to the conditional stuff
