  • Bas Schouten 135 posts 233 karma points
    May 07, 2013 @ 12:10
    Bas Schouten
    Error after submit
    Hy All,
    When a Contour form is sumitted we get the following error. The data is saved but we don’t get a normal submitted message.
    Can someone help me out?
    Greetings,
    Bas
  • Comment author was deleted
    May 07, 2013 @ 13:27
    Do you have any workflows attached on the approved state?
    May 07, 2013 @ 13:31
    Bas Schouten
    We only use "send email" on this form. The problem occurred on multiple forms.
    May 07, 2013 @ 13:38
    Ok the default send email? Could you tell me umbraco version and Contour version you are running?
    May 07, 2013 @ 13:55
    Bas Schouten
    Versions:
    • umbraco v 4.7.1 (Assembly version: 1.0.4281.20201)
    • Umbraco Contour - 1.1.4.1
    Also withoud workflows the error occurred.
    May 07, 2013 @ 13:56
    Bas Schouten
    Versions:
    May 07, 2013 @ 14:02
    Ok and anything attached to the contour event model? From the error I see ...Umbraco.AppicationBaseEvents.RecordApprovede (... is not visible) so I assume this is custom code? And looks like it's coming from the custom code...
    May 07, 2013 @ 14:49
    Bas Schouten
    Hi Tim,
    That was the problem. An external developer thought there was only one form ;-).
    May 07, 2013 @ 14:51
    Great, glad it's solved :)
