  • Michiel 30 posts 61 karma points
    May 16, 2013 @ 21:34
    Michiel
    Umbraco Exception (DataLayer): SQL helper exception in ExecuteNonQuery on Azure
    Hey,
    This week I installed Umbraco and Contour on Azure. It's not yet licenced, but when I try to hit send I get this error: Umbraco Exception (DataLayer): SQL helper exception in ExecuteNonQuery.
    I did find some old posts about stuff missing in the db, is this the problem here as well? Maybe because it's hosted on Azure. How can I fix it without breaking anything?
    Thx,
    Michiel.
    (Umbraco v6.0.5 + Contour version 3.0.11)
  • Tim Geyssens 6462 posts 15130 karma points MVP 2x c-trib
    May 21, 2013 @ 17:00
    Tim Geyssens
    Hmm I'll need to check this, creating forms works, it's just submitting that throws the error?
    May 21, 2013 @ 17:24
    Michiel
    Hey,
    At the moment I removed it from the page and made something myself, so I can't check it anymore.
    But I was able to make a form, save it and add it to the page. When I tryed to submit it I got the error. Maybe something went wrong with installing. But I had a problem with removing forms I made as well. Looked like a problem with rights. Can't find anything in my logs about a problem with contour.
    May 21, 2013 @ 17:28
    Tim Geyssens
    Ok thanks for the extra details, will do a test install on azure to see if I can reproduce ;)
  • Jeroen Wijdeven 31 posts 72 karma points MVP
    Jun 06, 2013 @ 15:35
    Jeroen Wijdeven
    I have the same problem. The problem occurs not only at submit but also at going to the next step. Is there any progress on this?
    I have also a problem with exporting the azure database because several UF* tables used by Contour do not have a clustered index, which looks similar to this problem: http://issues.umbraco.org/issue/CON-88 .. Maybe these two issues have a relation.
    Jun 06, 2013 @ 15:57
    Tim Geyssens
    Yeah currently testing so hope to have something ready tomorrow
    Jun 06, 2013 @ 16:41
    Jeroen Wijdeven
    2
    Excecuting the next script did the trick for me:
    CREATECLUSTEREDINDEX[UFFieldSettings_Index]ON[UFFieldSettings]([Field])
    CREATECLUSTEREDINDEX[UFRecordDataBit_Index]ON[UFRecordDataBit]([Key])
    CREATECLUSTEREDINDEX[UFRecordDataDateTime_Index]ON[UFRecordDataDateTime]([Key])
    CREATECLUSTEREDINDEX[UFRecordDataInteger_Index]ON[UFRecordDataInteger]([Key])
    CREATECLUSTEREDINDEX[UFRecordDataLongString_Index]ON[UFRecordDataLongString]([Key])
    CREATECLUSTEREDINDEX[UFRecordDataString_Index]ON[UFRecordDataString]([Key])
  • Scott Robinson 54 posts 75 karma points
    Jun 26, 2013 @ 10:58
    Scott Robinson
    Is there any solution on this? I have the same issue. Creating forms is fine, just the error when submitting from end.
    Jun 26, 2013 @ 11:26
    Jeroen Wijdeven
    See my last reply on June 6th. It's a hotfix but it did the trick for me
    Aug 09, 2013 @ 11:37
    Scott Robinson
    I've tried to add run this script on azure backend and it says:
    msg156, level 15, state 1, line 1
    Incorect syntax near keyword 'ON'
    Any idea why this would be?
    Aug 09, 2013 @ 11:42
    Scott Robinson
    Also, are there any versions of Contour that will work on azure out the box with Umbraco 6.1.2? I haven't been able to use this product at all.
    Aug 12, 2013 @ 11:06
    Tim Geyssens
    @Scott can you try the latest stable so 3.0.14
  • netzzeus 8 posts 28 karma points
    Dec 02, 2013 @ 16:03
    netzzeus
    I have the same problem with Contour 3.0.17, when I submit the contact form. I tried to reinstall contour, but the problem still exists.
    Is there already any solution?
    thanks!
  • Paul Crabb 22 posts 45 karma points
    Jan 23, 2014 @ 22:37
    Paul Crabb
    Umbraco 4.11.5 on Azure
    I have had problems deleting forms, saving forms, running forms - it's been driving me nuts !... I ran the following SQL from Chuhukon and it has transformed the way Contour is behaving. The problem with his original SQL is it has stripped out all the spaces so gave errors. Enjoy :)
    CREATE CLUSTERED INDEX [UFFieldSettings_Index] ON [UFFieldSettings]([Field])
    CREATE CLUSTERED INDEX [UFRecordDataBit_Index] ON [UFRecordDataBit]([Key])
    CREATE CLUSTERED INDEX [UFRecordDataDateTime_Index] ON [UFRecordDataDateTime]([Key])
    CREATE CLUSTERED INDEX [UFRecordDataInteger_Index] ON [UFRecordDataInteger]([Key])
    CREATE CLUSTERED INDEX [UFRecordDataLongString_Index] ON [UFRecordDataLongString]([Key])
    CREATE CLUSTERED INDEX [UFRecordDataString_Index] ON [UFRecordDataString]([Key])
  • Jesper Hauge 298 posts 486 karma points c-trib
    Apr 07, 2014 @ 10:39
    Jesper Hauge
    3
    For anyone stumbling over this issue, that are running the database in SQL Azure.
    As far as I can tell, there is currently only one table missing an index in the database: UFFieldSettings
    To make things work, you can run this script on the database
    BEGIN TRANSACTION
    SET QUOTED_IDENTIFIER ON
    SET ARITHABORT ON
    SET NUMERIC_ROUNDABORT OFF
    SET CONCAT_NULL_YIELDS_NULL ON
    SET ANSI_NULLS ON
    SET ANSI_PADDING ON
    SET ANSI_WARNINGS ON
    COMMIT
    BEGIN TRANSACTION
    GO
    CREATE CLUSTERED INDEX IX_UFFieldSettings ON dbo.UFFieldSettings
        ([Key]) WITH( STATISTICS_NORECOMPUTE = OFF, IGNORE_DUP_KEY = OFF, ALLOW_ROW_LOCKS = ON, ALLOW_PAGE_LOCKS = ON) ON [PRIMARY]
    GO
    ALTER TABLE dbo.UFFieldSettings SET (LOCK_ESCALATION = TABLE)
    GO
    COMMIT
    Happy Azure hosting
    .Jesper
  • Amigo 231 posts 505 karma points
    Apr 11, 2014 @ 22:17
    Amigo
    Cool Jesper, Thanks.
    Fixed my u 6.1.2 + c 3.0.19
