I'm currently using Contour 3.0.12 on Umbraco 4.11.8 and i get the folowwing error when I load the form page. Its using the RenderForm.ascx from ~/usercontrols/, i have tried replacing the install files from the Contour 3.0.12.update, and i still get the same error.
Uncaught Sys.ArgumentTypeException: Sys.ArgumentTypeException
Ideas?
Comment author was deleted
Hmm doesn't look like th error is coming from any Contour specific scripts
Did you try http://sympmarc.com/2010/08/28/how-to-fix-sys-argumenttypeexception-object-of-type-sys-_application-cannot-be-converted-to-type-sys-_application-error/
Alternatively you can just use the razor macro that shouldn't use a scriptmanager so you shouldn't get that error
