I've been translating hardcopy forms into Contour forms, and have found a scenario not currently catered for - I'd like to be able to set a mandatory, conditional field.
What I'd like to be able to do is set the conditional field to be mandatory, and have Contour recognise the field is conditional and therefore only mandatory if it is displayed.
ie:
Radiobutton - YES | NO
Textfield - This is conditional and mandatory.
If the Radiobutton above is no, Texfield is not mandatory as it is not displayed and can't be completed. If the Radiobutton above is yes, Textfield is mandatory as it is now displayed and must be completed.
Is there any way of doing this currently, or should it be raised as a request? I guess I could set a default value on the conditional field, but that could result in the default data being submitted with the form and pushed out into other data stores, which isn't ideal.
Mandatory conditional fields
ie:
+1 for wanting this feature.
Have you made a feature request on the Contour Issues Tracker?
