    May 31, 2013 @ 12:39
    Ismail Mayat
    Prevalues drop down
    Using contour 119 in umbraco 452.
    I have drop down field its pointing to prevalues source which is umbrac documents. 2 things firstly I want the value of the drop down to be node name not node id. Secondly is there way of having first item in dropdown something like Please select with no value?
    Regards
    Ismail
  • Comment author was deleted
    May 31, 2013 @ 13:12
    Hey Ismail,
    Unfortunalty in that version of Contour you'll need a customized version of the prevalue sourcetype, should be a quick update , shared sourcecode for all the default providers is available here http://our.umbraco.org/FileDownload?id=5060
