  • Kenny Burns 173 posts 305 karma points
    Jun 01, 2013 @ 17:54
    Kenny Burns
    Dropdown Prevalues
    I am currently using contour 3.0.12 and I am setting up some forms code first (nice work by the way! Totally awesome stuff!)
    I am trying to put some prevalues into a dropdown:
      [Field(FormPages.RegistrationBusiness, FormFieldsets.BusinessDetails,
              Type = typeof(DropDownList), Prevalues=new string[]{"Sole Trader", "Limited Company"},
              Mandatory = true)]
            public string BusinessType { get; set; }
    ...But I would like those prevalues to come from an umbraoco datatype if that is possible - if not is there a way to have prevalues have both a value and text?
    Hope that makes sense!
    Cheers -
    Kenny
  • Comment author was deleted
    Jun 03, 2013 @ 11:36
    Hey Kenny,
    Yeah for that you'll need to set a prevalue source so instead of setting the Prevalues set PrevalueSource
    You can also create prevalue sources from code
    As an example this creates one of the type UmbracoPrevaluesReadOnly (that uses datatype prevalues) of the datatype with id 1234
      [PrevalueSource("From umbraco")]
        public class CustomPrevalueSource: PrevalueSourceBase
            public override Umbraco.Forms.Core.FieldPreValueSourceType Type
                get
                    var prevalueSource = new Umbraco.Forms.Core.Providers.Prevalues.UmbracoPrevaluesReadOnly();
                    prevalueSource.DataTypeId = "1234";
                    return prevalueSource;
    Then on your form field set  PrevalueSource = "From umbraco" (so use prevalue source name)
    Jun 04, 2013 @ 22:08
    Kenny Burns
    Hi Tim,
    Thanks for that - this works a treat. Is there a way though that i can have the value of the source as the dropdown option value (its just using the string)?
    (does that make sense??! - see images below)
    I also was wondering if its possible to have a form that you can edit another users profile (i.e. http://www.nibble.be/?p=205 - Profile form but somehow have the default value come from a member you have loaded in from a querystring or something.)
    Sorry for all the questions!! I'm really enjoying the code first stuff though! :)
    Many thanks
    K
    Jun 05, 2013 @ 10:41
    Well I guess you could just update the view for that fieldtype to use the value instead of the text
    For the member edit, you can set defaults from querystring/session/cookie so maybe that could be usefull?
    Jun 05, 2013 @ 11:46
    Kenny Burns
    Ahhh! Yeah - i knew it would be something as easy as that (dropwdown) - perfect Tim.
    Yeah that would work - (members) - do you have an example of this anywhere?
    Thanks mate - really helpful! :)
    Jun 05, 2013 @ 11:54
    Yeah just set the default value to:
    Insert page value: [#propertyAlias]
    Insert recursive page value: [$propertyAlias]
    Insert cookie value or session: [%cookieValue]
    Insert value from request collection: [@requestKey]
    Jun 05, 2013 @ 11:56
    So would look like
     [Field("Profile", FormFieldsets.Details,
               Mandatory = true,
                DefaultValue = " [@requestKey]")]
            public string Name { get; set; }
    Jun 05, 2013 @ 12:16
    Kenny Burns
    Thats great Tim - thanks a lot. Will check that out tonight and let you know how I get on.
    Kenny
