According to the Contour download page, it has only been tested as far as Umbraco 4.9.1. We would like to begin using version 6.0 or maybe 6.1 soon. Is Contour supported on the 6.x versions of Umbraco?
Thanks, Tim. It just bothered me a bit that the info on this page http://our.umbraco.org/projects/umbraco-pro/contour seems to indicate otherwise. It says "untested" next to ever version higher than 4.9.1.
So just to be clear as I have a confidence license, if I install Contour 3.0 on Umbraco 6.1, it will be eliogible for support?
But basicly it's pretty simple for version lower then 4.7 use 1.1.9 for version between 4.7 and 4.10 use 3.0.6 for everything else just use the latest stable
Contour on Umbraco 6.x?
Comment author was deleted
Yup it should work on 6.x but make sure to use a recent release so a 3.x
Yup Contour also comes with support so once you have a contour license... or confidence is of course also valid
Just updated the compatibility :)
Thanks for the claification and the update. I feel much better. :)
