  • Nathalie 3 posts 23 karma points
    Jun 19, 2013 @ 13:25
    Nathalie
    XSLT errors after upgrading Contour
    I've just upgraded Contour to the latest version. Now I get these xslt errors everywhere. For instance, where my images slider should be this error appears instead: Error parsing XSLT file: \xslt\Slider.xslt
    I've checked the xsltExtensions.config file but it looks the same as the one from before the upgrade.
    What else can I do?
  • Comment author was deleted
    Jun 19, 2013 @ 13:41
    Hey Nathalie, what is the Umbraco version you are running?
    Jun 19, 2013 @ 13:43
    Nathalie
    Hi Tim, the version is 4.8.0.
    Jun 19, 2013 @ 13:44
    Yeah you probably installed a version that isn't compatible try version 3.0.6 or upgrade Umbraco to at leat 4.10
    Jun 19, 2013 @ 13:46
    Nathalie
    Thank you! I'll try that right away :-)
    Edit: It works much better now, thank you again!
    Jun 19, 2013 @ 14:04
    Great :) Just remember this for version lower then 4.7 use 1.1.9 for version between 4.7 and 4.10 use 3.0.6 for everything else just use the latest stable
