I have an field called "Address" I make a few updates to this field on the RecordService_RecordSubmitted event.
All good so far and i can view my updates to "Address" when i view the entries
My issue occurs when i add email workflows. The updates i made on "Address" have not been added during the email workflow.
Is there an event i can call that will be hit before the email work flow event. I've tried RecordService_RecordPartiallySubmitted but it didn't appear to work.
RecordService_RecordSubmitted hit after workflow
After further investigation it appears my theory that the RecordService_RecordSubmitted is hit after workflow is not valid.
I was able to get the updated record using the following code.
public static string GenerateHtmlTable(Record record) { var output = new StringBuilder(); output.Append("<table style=\"background: #eee; width: 100%;\">"); var fields = record.RecordFields; foreach (var key in fields) { try { RecordField recordField = record.GetRecordField(key.Key); if (recordField.Field.FieldType.Name == "13 Line Rule") { } else if (recordField.Field.FieldType.Name == "16 Description Heading") { } else { output.Append("<tr style=\"background: white;\"><td style=\"width:40%;\"><strong>" + recordField.Field.Caption + ": </strong></td>"); var values = new StringBuilder(); foreach (var value in recordField.Values) { values.Append(value); } if (recordField.Field.FieldType.ToString() == "xxx.Forms.Common.FieldTypes.Address") { if (!string.IsNullOrEmpty(values.ToString())) { values = values.Replace("|", ","); } } output.Append("<td style=\"width: 60%;\">" + values.ToString() + "</td></tr>"); } } catch (Exception ex) { } } output.Append("</table>"); return output.ToString(); }is working on a reply...
