Is this Contour datatype that allows filtering uploads by file type available for Razor? Or is there another?
http://our.umbraco.org/projects/backoffice-extensions/cogworks-cogfilteredupload
Comment author was deleted
Don't think so maybe try getting in touch with Ismail to see if he plans on adding support soon
Thanks Tim. Is there a reason why there is no RegEx field in the standard upload? I've hardcoded one into a custom version in a View which seems to work partially but doesn't like files with capital letters as the file extension:
@model Umbraco.Forms.Mvc.Models.FieldViewModel
<input type="file" name="@Model.Name" id="@Model.Id"
@if(Model.Mandatory){<text> data-val="true" data-val-required="@Model.RequiredErrorMessage"</text>}
@if(Model.Mandatory){<text> data-val-regex="Invalid file type, only png, jpg and gif allowed" data-regex="^.+\.((jpg)|(gif)|(jpeg)|(png)|(JPG)|(GIF)|(JPEG)|(PNG))$"</text>}
@if (!string.IsNullOrEmpty(Model.Value))
<br />
<a href="@Model.Value" target"_blank">Show current file</a>
<input type="hidden" name="@{@Model.Name}_file" value="@Model.Value"/>
CogFiltered Upload for Razor
@if(Model.Mandatory){<text> data-val="true" data-val-required="@Model.RequiredErrorMessage"</text>}@if(Model.Mandatory){<text> data-val-regex="Invalid file type, only png, jpg and gif allowed" data-regex="^.+\.((jpg)|(gif)|(jpeg)|(png)|(JPG)|(GIF)|(JPEG)|(PNG))$"</text>}{<input type="hidden" name="@{@Model.Name}_file" value="@Model.Value"/>is working on a reply...
