  • suzyb 476 posts 934 karma points
    Jun 25, 2013 @ 14:47
    suzyb
    HideLabel
    I see there is a boolean check on a property HideLabel but I can't see where in the form designer I can set labels to be hidden.
    Am I just missing the propery or is the functionality incomplete.  I'm using contour 3.0.12.
  • Comment author was deleted
    Jun 26, 2013 @ 12:12
    Hey,
    Well this is set on the fieldtype and isn't possible to set with the designer
    Tim
    Jun 26, 2013 @ 14:37
    suzyb
    How do you mean, set on the fieldtype.
  • James Wilkinson 15 posts 72 karma points c-trib
    May 29, 2014 @ 13:05
    James Wilkinson
    I've just come across this post as I am wondering the same thing :)
    Is there any way for us to set this property so that the labels can be hidden for a couple of the fieldtypes but not for others?
    James.
