  • sami 22 posts 104 karma points
    Jun 27, 2013 @ 14:34
    sami
    DatePicker in IE 10 is not working
    DatePicker it works good in all browsers except IE 10, then I ran script debugger it says js error :
    "__doPostBack" is undefined
  • Comment author was deleted
    Jun 27, 2013 @ 14:37
    Hey Sami,
    I asume you are using the usercontrol macro right? Also mind sharing the Contour version you are running?
    Jun 27, 2013 @ 14:42
    sami
    Hey Tim,
    I am using:
    Umbraco version: 4.11.8
    Contour Version: 3.0.12
    Jun 27, 2013 @ 14:46
    Hey I would recommend that you switch to the razor macro, that doesn't use webcontrols so won't have that issue
    Jun 27, 2013 @ 15:00
    sami
    <asp:content ContentPlaceHolderId="ContentPlaceHolderDefault" runat="server">
    <umbraco:macro Alias="Info" runat="server" />
    <umbraco:Macro FormGuid="193047a3-9f2f-4507-b83a-a3f76d3b1508" AllowEditing="1" SubmitButtonText="Submit" NextButtonText="" PreviousButtonText="" PageNameTag="" Alias="InsertformfromumbracoContour" runat="server"></umbraco:Macro>
    </asp:content>
    Jun 27, 2013 @ 15:07
    Yeah looks like you are using the usercontrol macro, try inserting the macro again but choose the razor version
