When i create a new form in contour a default work flow is created.
How do i disable this workflow so there are no workflow
Comment author was deleted
Hey Anthony you can disable this in the config file found at \Umbraco\Plugins\umbracoContour\UmbracoContour.config, there is a setting in there called DisableDefaultWorkflow just set that to true
If you don't have that setting you are running a pretty old version and can upgrade :)
Just checked the change log, added since version 3.0.8
cool, thanks for the speedy response. Works.
Great :)
how to disable default workflow
Great :)
