  • Fergus Davidson 309 posts 588 karma points
    Jul 01, 2013 @ 12:29
    Fergus Davidson
    contour workflow '...or pick a static value' not working
    Umbraco 4.11.5
    Contour 3.0.12
    Contour Member Tools 1.0
    when i add a workflow [Save as umbraco member when Submitted] in the workflows dialogue, i want to set a static value to combine two fields.
    on selecting the '...or set a static value' option, the field just remains as-is - it does not swap for a text field allowing me to enter a custom static value.
    Any ideas:
     - why this doesn't work/how it can be fixed
    - where in the DB i could manually add the value?
    thanks
  • Comment author was deleted
    Jul 01, 2013 @ 12:31
    Hey,
    Do you get any js errors?
    Jul 01, 2013 @ 12:35
    Fergus Davidson
    'pickfield is not defined'
    think it might be the workflow as it works for others [e.g. save as umbraco document]
    Jul 01, 2013 @ 12:40
    Yeah it's a third party one (whole member tools is) with a custom setting control that looks like it's causing the issue, will have a look
    Jul 01, 2013 @ 12:43
    Fergus Davidson
    Great!, thanks Tim.
    Jul 01, 2013 @ 12:44
    Jul 01, 2013 @ 13:10
    Looks like the embedded script resource is failing to load, looking into a fix now
    Jul 01, 2013 @ 13:24
    Ok found a fix, update is available here: https://www.dropbox.com/s/kczvavkmv7xzme3/MemberToolsUpdate.zip (just extract and drop in your bin dir)
    Jul 01, 2013 @ 14:27
    @Fergus, can you confirm that it works now?
  • Josh Olson 79 posts 207 karma points
    Aug 12, 2013 @ 15:48
    Josh Olson
    I just ran across the same problem, used the 'fix' package, and I can confirm that it is now allowing me to enter text when choosing 'set a static value'. Thanks!
  • Richard Barg 358 posts 532 karma points
    Jul 24, 2014 @ 17:27
