Is it possible to create a form and define label text in different languages with the correct lanaguage displayed depending on the Culture?
Comment author was deleted
Yup Contour supports the use of dictionary items, so just setup your multilingual site as you would (using languages and dicitonary items) and then for the captions in Contour you can use #dictionaryKey
Simples,
Yup :) same goes for the error message and all places where you can insert copy :)
internationalisation possible?
Simples,
