  • Nick 101 posts 123 karma points
    Jul 03, 2013 @ 13:06
    Nick
    Problem running Contour
    I used to have Contour running on a project but I recently tried to load the project on a new hard drive (same machine) and Conour doesn't run.
    I am using Umbraco version umbraco v 4.11.6 and I think it's version 3 of contour although I can't easily find what version it is.
    The problem I get is:
    c:\Projects\...\umbraco\plugins\umbracoContour\Views\Script.cshtml(2): error CS1525: Invalid expression term 'abstract'
    So the problem is on line 2 of Script.cshtm file:
    @using Umbraco.Forms.Core
    @abstract  Umbraco.Forms.MVC.Extensions <-- abstract isn't understood
    @using Umbraco.Forms.Mvc.Models
    Since Contour can't understand something so fundamental as the "abstract" keyword, I am guessing this could be a problem relating to .NET or MVC version?
    Any ideas what it could be?
    Project is running on .NET 4.5 with MVC 3
    Thank you
  • Comment author was deleted
    Jul 03, 2013 @ 13:47
    By default the top of that file looks like
    @inherits WebViewPage<Umbraco.Forms.Mvc.Models.FormViewModel>
    @using Umbraco.Forms.Mvc.BusinessLogic
    @using Umbraco.Forms.MVC.Extensions
    So I'm assuming you changed something? Try changing abstract to using again
    Jul 03, 2013 @ 15:08
    Nick
    This is very odd.
    This fixed it. Need to investigate how it got mangled like that, I suspect maybe resharper automated clean tool might have done it.
    Regardless, thank you very much
    Jul 03, 2013 @ 15:13
    Ok glad it's working now :)
