Topic author was deleted
Jul 03, 2013 @ 20:01
Contour 3.0.13 changes
Contour 3.0.13 is out today!
Here is an overview of the changes:
3.0.13 - July 2013
Fixed: SQL create script update due to some sql azure issues Fixed: CON-364 Avoid An item with the same key has already been added error on RecordFieldStorage Fixed: CON-392 Make sure if a users imports a form he has access to that form Fixed: CON-393 Make sure validation of checkboxlist doesn't fail if markup is updated Fixed: CON-375 File upload issues with IE (if it includes local directory path)
3.0.13 - July 2013
You can get it from the project page http://our.umbraco.org/projects/umbraco-pro/contour
Upgrade instructions available here http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Upgrade
