  • Ron Brouwer 273 posts 768 karma points
    Jul 05, 2013 @ 16:34
    Ron Brouwer
    Filtering is not allowed.
    I get the message "Filtering is not allowed." in both the preview of the form and on my site.
    The site is running Umbraco 6.0.4
    Can you specify why this error might occour?
    Thanks an advance!
  • Comment author was deleted
    Jul 09, 2013 @ 10:31
    Hey Ron,
    That's strange, did you make any changes to the form views so far?
    Jul 09, 2013 @ 10:33
    Will try a test install with that some version to see if I can reproduce
    Jul 09, 2013 @ 10:36
    Ron Brouwer
    Hey Tim,
    I've located the problem. It's caused by an ActionFilter that we use for all our sites to modify the page output. I'm not sure why this is causing problems with Contour. We never had issues before.
    Any idea?
    Jul 09, 2013 @ 10:42
    Just tried with a fresh 6.0.4 installing latest Contour 3.0.13 and that works fine...
    @Ron are you also running latest Contour or an older version?
    Jul 09, 2013 @ 10:43
    Ah ok glad you found it, possible solution here: http://forums.asp.net/t/1634304.aspx/1
    Jul 09, 2013 @ 11:05
    Ron Brouwer
    I've seen that post but it's not helping. I think I know why this happens. It seems that you override the HttpContext.
    When checking for filterContext.IsChildAction in my attribute it returns False when it should return True. Could that have something to do with you overiding some things?
    Jul 09, 2013 @ 11:07
    Well it is using mvc bridge http://our.umbraco.org/projects/developer-tools/mvcbridge (to support older Umbraco versions) so I suppose that in that code it might be overriding the HttpContext
